Scribing Panel Lines on Metal Bodies
jaxenro
Post by jaxenro » Wed Jul 01, 2015 11:16 am
In all my puttying and priming and sanding I lost some panel lines how do I go about rescribing them?
Re: Scribing Panel Lines on Metal Bodies
Post by Jean B. » Fri Jul 03, 2015 1:54 pm
Don't know exactly what you mean... If you mean elevated/embossed lines apply lots of putty and remove everything you do not need after drying with either a file or with machined mills or discs. It's a kind of sculpturing...
If you mean engraved lines, make a pattern of cardboard or 0.5mm polystyrole sheet, fix this with double-sided adhesive tape on the coachwork and get along carefully with a scriber (stainless steel works best). White-metal is very soft, so this is quite easy.
Post a good photo of the questioned part, perhaps I can submit more information then.
