Making better aerials
Post by LUW » Tue May 01, 2018 5:41 pm
I think most people think that guitar strings are ideal to make good aerials, but I never used that technique. What I used back in my 1:18 days was acupuncture needles, and they always worked fine for me, and can also be used for 1:43rds. My recent Le Mans winning Mac had a bad aerial, that was a tad too thick and worse, was crooked. So I thought of making it look better using a needle.
Acupuncture needles come in different sizes and thickness, from hair thin to about 0.5 mm ø. And best of all, they come with a handle that is perfect as the base for the aerial.
You will need a pair of tweezers, a good cutting pliers and obviously glue.
So I cut a section of the shaft of the needle and a small piece of the handle, and than it was just a matter of removing the ugly plastic one and stabbing the new one in the hole on the roof, with an itsy-bitsy drop of glue.
A 5 minute job and now it looks much closer to the real thing.
I'm sure you will agree that that looks MUCH better than how it looked before.
Re: Making better aerials
Post by Galaxy Gaz » Tue May 01, 2018 7:05 pm
Great job, looks easy enough to do and the car looks much better now ;)
Post by LUW » Tue May 01, 2018 9:55 pm
Stupid easy, in fact. I think the hardest part is to find the needles, but they're usually available in medical supply stores. And a couple are good enough for quite a few cars.
Just be careful with the pointy end :D
Post by Jager » Wed May 02, 2018 1:35 am
That's a great tip Luc.
I thought the needles might be difficult to find, but there are 2,000 on eBay.
What size did you use ?
Post by johann.nunweiller » Wed May 02, 2018 3:02 am
Good idea!
Post by JSB33 » Wed May 02, 2018 5:54 am
I thought this post was called making better areolas, never mind.....
Post by LUW » Wed May 02, 2018 6:53 am
No, for that you use a pump.
Good idea!
Thanks Johann!
The shaft was from the big one, that is 0.25×75 mm, and for the base I used the small one, that unfortunately I can't understand what's written on the package (Chinese :roll:) - but I think it's something around 0.15×25 mm. In my eyes the small one would look too thin as a "main" aerial but would be perfect for those smaller secondary ones on more modern cars.
MadMike
Post by MadMike » Fri May 04, 2018 9:23 am
Hmmmm looks good Luc.
But for me im staying away from them, as I girl I sort of met was all about pressure points and them silly needles, she stuck a bunch into my back. Well I fell asleep and rolled over, yep ouch to say the least. (Yes more to that story but this is a car forum so, nup)
Good write up and details buddy.
Have to say tho it would do great for the General Lee from the Duke of Hazard.
Cheers.
:!: DONKEY :!:
Post by LUW » Fri May 04, 2018 9:26 am
:lol: WARNING: Only to be used with parental guidance!
The General would benefit a LOT from a needle.
