Jager wrote: ↑Sat Jun 27, 2020 7:35 am
I don't think it's about research, it's about costs.
This! And that's the exact same reason why Minichamps keeps recycling thesame castings over and over again. Casting is expensive, if you're not able to sell thousands, you can't even cover the costs of a brand new metal mold. Tooling for die-casts can cost over 100.000 dollars for each model
It's a matter of deciding if you can live with it or not. If you can't, there's always the option to buy the model and update the model yourself.
Jager wrote: ↑Sat Jun 27, 2020 11:47 am
Thought you might like to see a different version of the Brabham Martini transporter I have in my files Bruno. I'm not sure where I found this, but I wonder if the Ford cab relates to the Ford engines?
Thanks for sharing, Ian. I've never seen this truck before, I can only imagine what else you could have in your vault.
This is a Ford C-Series, it was a common sight at the paddock among F1 teams. The Copersucar-Fittipadi team had a similar model used in the European races.
It's also an interesting photo because the decoration suggests thispicture was taken in 1975, since Brabham didn't have the Martini Sponsorship in 1974 and they droped the Ford engines by the end of 1975. Generally speaking, the major F1 teams in the mid-70's had at least two diferent transporters for the European races. While one of them was dispatched to a race, the other one was at the factory already being prepared for the next race. Since Ixo suggests that the Volvo was used from 1974 to 1976, perhaps they had these two transporters in 1975 to support the team in the European races.
I can see that there is another transporter just behind, but I can't tell from which team it is nor the make/model. The trailer side skirts suggest it's the Volvo, but the decoration and the shape atthe front of the trailer are different. Perhaps it's a picture taken early in 1975 and it still had the 1974 decoration.
