Simple diorama of derelict land
orky
Re: Simple diorama of derelict land
Post by orky » Tue Dec 20, 2016 1:38 pm
Thanks guys for the info - really helpful.
I wasn't even aware the ghia's do not have a spoiler :lol: however on the atlas model the spoiler is one unit with the rest of the bodywork and does not come off. Therefore it would have been a 2.8 injection model but....
I see what you mean about the atlas model compared to 1:1. IMO vanguards has the best model shape of the mk3 capri but badly let down by the base/front valance trim and rear being a separate unit to the rest of the body. Otherwise the model is very crisp and spot on. Atlas model seems IMO too thick and not as crisp as vanguards. + I've noticed the nose is too thin length-wise, and there's additional black pillars either sides of the nose in-between the headlights. This is probably why the nose isn't as wide as it should be. On the real (and vanguards) version the additional black pillars do not exist - and it's impossible to get rid of the these without ruining the model.
Anyhow, the atlas project has failed! Will switch back to the vanguards after xmas. I already have a stripped ghia shell and because of the amount of work required to make the body one whole unit I will respray it black. This'll make it easier because of all the black panels/ window trims etc.
orky
Post by orky » Mon Mar 06, 2017 2:36 pm
The Capri is coming along really nicely albeit the slow progress... just a quick question though, can you get an original mk3 capri GL model with the same ghia bumpers? The ghia/injection bumpers have the overrides on whereas the lower spec models have the flat bumpers. I'm turning this model into a GL but need the correct bumpers, thanks in advance
orky
Post by orky » Sat Mar 11, 2017 2:15 pm
they have the flat bumpers so in the process of doing these, so a bit of a hold up but finished pics should be up next weekend.
Will be a mk3 GL model with the GL wheeltrims, spares taken from cortina mk4 which are exactly the same and fit flush on the capri.
orky
Post by orky » Sat Feb 10, 2018 2:47 pm
a few new models have been completed/resprayed and I hope to have the pics up soon, but have run out of numberplates!
1) Black Rover SD vitesse (minichamps). This was pretty much a straight forward respray job and quite an easy conversion compared to the others.
2) Yellow mk1 Vauxhall Astra L 1300S (minichamps). Relatively straighforward a bit like the rover but needed some filing work at back of the model which was originally too low so had to get rid of some of it just below the bumper.
3) light-blue mk3 ford escort 1.3L (minichamps). Mammoth amount of work including making the side windows bigger as they were too small originally. Also front bonnet above the grille needed fixing initially using a dremel then filing in and sanding straight using filler - unfortunately on all the minichamps version there's a dent and once you notice you can't fail to notice. But really pleased with the end result after fixing.
4) Two-tone chocolate brown/coffee beige mk2 Ford Granada 2.8 ghia (vanguards). As per usual on a lot of these vanguards models the base is a separate unit to the rest of the model so needed working on to make the model one whole unit just like the real thing. Although ghia's weren't available in two-tone colours this is a one-off special edition as far as I'm concerned ;) Has all the ghia trimmings and the top half of the model is brown, and the bottom, below the bumpers and side panels is coffee beige, much like the mk3 capri injection models.
Hoping to put pics up soon but need to get some waterslide numberplates first and can't find any around at the mo :(
orky
Post by orky » Wed Jun 20, 2018 1:18 pm
trying to upload some pics but unable to from photobox or photobucket :(
cannot hover over IMG code and paste onto here... been a while since I last posted pics here and it looks likes there's been changes which I'm not up to date with? :cry:
ImageVanguards ford sierra XR4i by mg ork, on Flickr
orky
Post by orky » Wed Jun 20, 2018 1:39 pm
ok, managed to post from flickr which seems to be working alright.
Above is a picture of a sierra I've resprayed yet again to try and get one that resembles the 1:1 model.
Lots of work done on the front headlights, front nose and all four bumpers.
Front headlight surroundings on the nose made bigger by carving with a knife, the headlights are thin acetate paper and the actual lamps are shiny kitchen foil which sits on the base of the model. The inner lamps left original and outer ones blunted and touched up with grey/black pen.
All bumpers have been filed/sanded as they were originally way too big, and particular attention has been given to the front fog lights/indicators as they were placed too high so have been positioned lower. Initially it was particularly noticeable when the red strip was put on at the front of the front bumper it was too high compared to the rest of the model, where the strips were lower and this made the model look horrible. The front strip now sits where the foglights/indicators were therefore in sync with the rest of the red strips.
Would love to post more pics of this and more models I've done however also struggling with camera settings :lol: as pics seem to be too blurry despite turning on macro.
orky
Post by orky » Thu Jun 21, 2018 1:48 pm
a few more pics of the sierra with a resprayed minichamps ford escort mk3, converted into a 1.1L.
Some work done to smooth over the front of the bonnet directly above the grille as the minichamps version have slight dents on them noticeable under lighting.
Image1981 ford escort 1.3L and 1983 ford sierra xr4i by mg ork, on Flickr
Side window surroundings carved with craft knife as initially minichamps made the windows way too narrow so they've been made bigger. Thick acetate paper used for windows.
Imageford escort 1.3L & sierra xr4i by mg ork, on Flickr
steel hubcaps replace the black ones as standard on these L models - this was done using silver coloured pen.
Imageford sierra xr4i and ford escort 1.3L by mg ork, on Flickr
on both models (I've started doing these on all my models) custom windscreen wipers made as vanguards ones are too thin.
Imageeighties classics by mg ork, on Flickr
Unable to do pics of back of model as run out of appropriate letters/numbers so yellow numberplates are blank!
Post by Tom » Thu Jun 21, 2018 2:11 pm
Impressive detail work!
Post by LUW » Thu Jun 21, 2018 5:24 pm
The Escort, specially, looks outstanding!
orky
Post by orky » Fri Jun 22, 2018 6:28 am
thanks guys.
Here is the Escort again this time in a water diorama which I'd been meaning to do for a few years and have finally got round to it - wasn't easy!
Imagedon't go in the water! by mg ork, on Flickr
orky
Post by orky » Fri Jun 22, 2018 8:01 am
joined by the trusted cortina!
Imageescort and cortina by mg ork, on Flickr
Post by dcast » Fri Jun 22, 2018 9:00 am
Nice idea for diorama.
orky
Post by orky » Fri Jun 22, 2018 10:30 am
thank you. Last picture edited to add a resprayed minichamps rover SD vitesse. I'd like to take pics of this model in full but it only has the blank white and yellow numberplates so therefore not totally complete.
Post by JSB33 » Sat Jun 23, 2018 8:55 am
Very charming dio.
orky
Post by orky » Sun Aug 05, 2018 5:13 am
Thanks.
Here is a ford capri from vanguards, which has been resprayed nut brown, a 1.6GL.
Imagenot quite The Professionals! by mg ork, on Flickr
Mammoth amount of work has gone into the model, vanguards didn't make the shell as one unit which was a big let-down IMO so this has been rectified, filling in the gaps by the front and back wheel arches and below the side panels.
Imagevanguards ford capri mk3 by mg ork, on Flickr
Image1981 ford capri by mg ork, on Flickr
Numberplates was originally painted on to the bumper on vanguards; I've stuck on a separate border for the numberplate and made it an X-reg 1981 model. Also, the grille has been made slightly thinner by sanding the top and bottom, as originally it was too thick. Thin windscreen wipers replaced by custom made ones.
Imageford capri mk3 1.6GL by mg ork, on Flickr
orky
Post by orky » Sun Aug 05, 2018 5:16 am
...and back of model also has slight changes, originally the numberplate was too small and lights too big and this was all one unit. Lights have been cut off by the edges and bigger number plate put on.
Imagevanguards ford capri, code 3 by mg ork, on Flickr
Unfortunately I do not have the bootlid capri logos.
The interior has been made cream beige.
The mk3 Capri always reminds me of The Professionals although the ones driven by Bodie and Doyle were higher spec than GL.
Post by Tom » Sun Aug 05, 2018 5:25 am
Nice detail work!
Post by dcast » Sun Aug 05, 2018 8:21 am
Nice model. Before and after pics would be nice when you do mods ;)
orky
Post by orky » Mon Aug 06, 2018 4:19 pm
thanks.
You are right, before and after pics would be better instead of me just blabbering on :lol:
I'm currently working on a mk2 series 1 granada, although I've done a few of these in the past there's nothing like the attention to detail I'm putting on this one. Most noticeably at the rear of the model below the bumper doesn't have enough showing and therefore not low enough - it is too narrow on vanguards so has been 'extended and now there's more bodywork showing just under the back bumper.
Shame I haven't taken a pic of the original vanguards model :evil: would have been easier to see what I mean.
And I've since done a tiny bit more work on the capri - the back lights have had the top and bottom filed to make them look thinner as they were still too thick. Hopefully pics of this and the completed granada up in a few days.
orky
Post by orky » Thu Aug 09, 2018 7:24 am
Here is the capri again with the corrected back lights, they look slightly more realistic after been made thinner.
Still working on the granada, won't be finished any time soon :lol: . The Rover still doesn't have a front badge or registration number so not able to see it in full view, don't know where I can get the front badge made, the ones I got from ebay were really poor quality and did not show on the black background.
Imageclassic car park by mg ork, on Flickr
orky
Post by orky » Thu Sep 27, 2018 5:40 am
A bit of help needed please guys ;)
I am in the process of converting a vanguards series 3 mk2 cavalier SRI into a very early mk2 series 1 SR model. Were all the series 1 SR's/SRi's two toned colours? ie dark grey below the bumpers? I'm hoping the answer is no as it would make my job easier if I had to use one colour paint!
Thanks in advance
Post by Galaxy Gaz » Thu Sep 27, 2018 7:52 am
You arent that lucky im afraid.
The SR and SRi`s all had Anthracite lower bodywork ;)
orky
Post by orky » Thu Sep 27, 2018 8:57 am
thanks, unfortunately feared as much!
The extra work is not too much of a problem, as I've resprayed two-tone coloured models before, however I just think having the lower-body in the same colour looks much better.
I would have converted to a lower spec mk2 s1 cavalier however do not have the appropriate wheels. I'm using the BoS Opel equivalent - namely the wheels and front valance trim - on the existing vanguards to make it an early mk2 SR or SRi model. At the moment working on the front nose as the s3 and s1 noses differ considerably.
Post by Tom » Thu Sep 27, 2018 9:34 am
All SR and SRI versions here had the black trim too.
